Hello,
I have a nissan vanette (lion face), I recently went to my mechanic to fix a problem and I found out that my van has 2 air filters. The normal air filter is near the front tyre and the other extra air filter is under the driving seat. The second air filter is also functioning perfectly along with the first one.
I am surprised because normally a vehicle has only one air filter. I would like to know from other vanette users whether you guys too have 2 air filters?
Can this be some kind of modification by the previous owner? Is it good or bad to have a second air filter
By the way my vanette is 2wd and its manual. Engine is the r2 engine.
Thanks.
Is R2 the new engine or is it RF the new one? I have two cousins who have Venettes' one has the old while the other has the new. I can check in their vans
Edit: Near which front tyre did you find the first air filter?
Edited by Magnum
Killercruise
Make sure this is not a cabin air filter, best way to check is Start the engine and check both sucks the air IN
- This is just an idea
regards
JC
@magnum its the r2 engine (not the new sensor engine).
The first air filter is near the left front tyre.
@john I havent checked like that . Ill give an update on that.
Thanks for the replies guys ;).
Killercruise
regards
JC
I checked it today. It works at the same time with the first air filter. I also found out that the second air filter has a direct connection with the first air filter. are
