Toyota Rav4 Mk2 - 4 Door And 2 Door Size Different
chamatharavinda
Okay...jokes aside...not really...they both come in either 1.8 ltr for the 2wd of 2.0 ltr for the AWD.
The 1.8 engine is the 1ZZ-FE engine and the 2.0ltr is the 1AZ-FSE. Has the same suspension and brake setup; has the same AWD system. Only thing is the 3-door is a bit tight on space. and didn't do well on the safety ratings for rear end collisions. Also because it is a bit lighter is a bit better on fuel (apprently...never owned one myself). Drove a first gen 3-door and that was quite nippy because of its size so I guess the MK2 would be the same ?
Edited by iRage
thanks...yes..from pictures i think a space difference is there...
  On 1/3/2015 at 6:19 AM, chamatharavinda said:
looking to get some idea about outer body size....
1. Could you please reduce the size of your signature pic or what ever you call it ?
2. Never bothered to look..here are the links to the pre-facelift and facelift models..go through it maybe there is a diagram at the end.
Pre-facelift
http://cdn.toyota-catalog.jp/catalog/pdf/rav4l-u/rav4l-u_200005.pdf
Facelift:
http://cdn.toyota-catalog.jp/catalog/pdf/rav4l-u/rav4l-u_200308.pdf
Pre-facelift
Facelift:
thanks
