Eagle Eye Posted January 6, 2019 Share Posted January 6, 2019 On 12/1/2018 at 3:30 PM, Goro said: Thanks for these step by step instructions. However , digging a little deep on this, I just found out that img file is actually an garmin compatible OSM (OpenStreetMap) , not actual garmin maps for Sri lanka. Actually you can download latest 2018 September OSM maps for Sri Lankan region from their site for free. And I also saw there's actual garmin 2018 maps for Sri Lanka for sale online for $19 and $29. If I purchase this will it be compatible with Honda indash system? Or does OSM have more routing data for Sri Lanka than Garmin?How do you know they are actually original Garmin maps?Sent from my AGS-L09 using AutoLanka.com mobile app powered by Tapatalk Quote Link to comment Share on other sites More sharing options...
WIKUM100 Posted March 9, 2019 Share Posted March 9, 2019 thanks for the all who help in this forum ,i have succesfully done the srilankan update for honda crv 2018 aussi model steps 1. update the prevailin aussi maps as describe by the https://honda.garmin.com/honda/site/generalInstructions follow the instruction and see the video as well https://static.garmincdn.com/autoOem/honda/docs/en.pdf https://vimeo.com/176223246/324d0e0f5a after that install garmin express software in to your pc as in this pdf instruction https://static.garmincdn.com/autoOem/honda/docs/en.pdf then after aussi update complited come to your pc and go to this site and downlord the srilankan map as a img file http://garmin.openstreetmap.nl/ (it save as (gmapsupp.img) it is about 58 mg } select Mapnik Country as Srilanka in the filling then replace the same file in the usb which is a 42 mb file now again go to the vehicle and do the update process after starting the vehicle now you are done Quote Link to comment Share on other sites More sharing options...
WIKUM100 Posted March 9, 2019 Share Posted March 9, 2019 https://vimeo.com/176223246/324d0e0f5a Quote Link to comment Share on other sites More sharing options...
Ishantha84 Posted June 22, 2019 Share Posted June 22, 2019 when map update is downloaded to usb pen drive from garmin express, it has two .img files (gmapsup1 & gmapsupp). So replacing gmapsupp.img with sri lanka map will do the trick or do I need delete the other .img file ? Quote Link to comment Share on other sites More sharing options...
Ishantha84 Posted June 25, 2019 Share Posted June 25, 2019 replaced only the gmapsupp.img file with downloaded SL map. everything work fine. thanks @WIKUM100 Quote Link to comment Share on other sites More sharing options...
MalithCS Posted September 19, 2021 Share Posted September 19, 2021 Anyone has the latest downloaded map from http://garmin.openstreetmap.nl/ Now there is no download option. I couldnt find a way to download the map. How about Mapmania.info website to download the map Quote Link to comment Share on other sites More sharing options...
Sylvi Posted September 19, 2021 Share Posted September 19, 2021 Members, I don't think that you need a map on smart phones. I travel out of Colombo then I use the map on the phone that gives all I need. Sylvester Wijesinghe Sylvi. Quote Link to comment Share on other sites More sharing options...
Hardyxy9 Posted July 11, 2023 Share Posted July 11, 2023 hello, to use maps on the smart phone, you must have a data card for internet connection - how much data I will need in 30 days travel? which provider do you recommend when I want to travel around Sri Lanka? I will get a prepaid SIM card at the airport? Thank you, Quote Link to comment Share on other sites More sharing options...
Angelo Desmond Posted August 30, 2024 Share Posted August 30, 2024 Guys, I have an audi a5 b9 2019 with a virtual cockpit (VC). Is it possible to get Sri Lankan maps on the VC? Please help Quote Link to comment Share on other sites More sharing options...
