Garmin Gps Maps For Sri Lanka
B2Spirit
  On 12/1/2018 at 3:30 PM, Goro said:
Thanks for these step by step instructions. However , digging a little deep on this, I just found out that img file is actually an garmin compatible OSM (OpenStreetMap) , not actual garmin maps for Sri lanka. Actually you can download latest 2018 September OSM maps for Sri Lankan region from their site for free.  And I also saw there's actual garmin 2018 maps for Sri Lanka for sale online for $19 and $29.  If I purchase this will it be compatible with Honda indash system?  Or does OSM have more routing data for Sri Lanka than Garmin?
How do you know they are actually original Garmin maps?
Sent from my AGS-L09 using AutoLanka.com mobile app powered by Tapatalk
  • 2 months later...
thanks for the all who help in this forum ,i have succesfully done the srilankan update for honda crv 2018 aussi model
steps
1. update the prevailin aussi maps as describe by the https://honda.garmin.com/honda/site/generalInstructions  follow the instruction and see the video as well https://static.garmincdn.com/autoOem/honda/docs/en.pdf
https://vimeo.com/176223246/324d0e0f5a
after that install garmin express software in to your pc as in this pdf instruction https://static.garmincdn.com/autoOem/honda/docs/en.pdf
then after aussi update complited come to your pc and go to this site and downlord the srilankan map as a img file http://garmin.openstreetmap.nl/    (it save as (gmapsupp.img) it is about 58 mg } select
 Mapnik
Country as Srilanka in the filling
then replace the same file in the usb which is a 42 mb file
now again go to the vehicle and do the update process after starting the vehicle
now you are done
  • 3 months later...
  • 2 years later...
Members,
I don't think that you need a map on smart phones. I travel out of Colombo then I use the map on the phone that gives all I need.
Sylvester Wijesinghe
Sylvi.
  • 1 year later...
hello,
to use maps on the smart phone, you must have a data card for internet connection -
how much data I will need in 30 days travel? which provider do you recommend when I want to travel around Sri Lanka? I will get a prepaid SIM card at the airport?
Thank you,
  • 1 year later...
