I have a issue with my remote key. Sometimes it is working perfectly and sometime it is not. so i have replaced the battery and still the problem is not yet solved.
Is there a good place or good electrician to fix this problem ??. I think someone who has the knowledge about the mazda electrical system.(near colombo)
Edited by mazda3@snej
I think for these type of issues you either need to go to the agent or a specialist like Mazna.
Also those so called car security system experts (eg. Sun Lanka) may be able to help.
Yeah but you have to realise that installing a Sun Lanka system is a lot cheaper than repairing the original. So thats the way its likley to pan out over there and you are not likely to get much help with the original.
I too had the problem in 2009 when I had a Mazda 3. At one point the car never responded to the remote. tried different places including carmart, sunlanka, magcity etc. Didn't work out. There is this garage called Upul's garage & electircal works in peliyagoda in the kandy road. If going from colombo, its on the right side. He fixed it. the charges if I'm was a bit higher than what I expected.
I can recommend you both Colonial Motors and Mazna Motors. I don't have experience with the same issue. But both places have done a good job every time I drove there. Mazna Motors should be easy on your pocket.
