Pajero V46 4Wd Indicator Flashing
Guys my pajero s 4wd indicators in the dash started flickering intermittently .but the system is working fine..appreciate any advice on what causes this , before the mechanics start with thousand and one reasons..thanks in advance...
1 answer to this question
Common issue with Pajeros. Check the connectors and solanoids under the car. Might have gotten clogged/loose and contact is poor. Also could be a case of a vacuum issue (but then the system works without delay and no premature/unexpecteddisengagement ?).
Do a search on the forums was discussed extensively. Do a web search too. Tons of sites about aprobleand quite a lot of DIY stuff u can do before letting a mech open it up
