Project 3: Land Rover Defender 300Tdi To A 2015 Defender 2.2 Puma
EAP
Hi Everyone
Its been a while since I visited the forum, Hope everyone is well and sound. I have just Completed my PROJECT 3 which was a 32-xxxx Land Rover DEFENDER 110 300tdi in to a LAND ROVER DEFENDER 2014 PUMA 2.2 TDCI .
Did this conversion by Using the same Chassis but all other parts including all genuine land rover NUT and BOLTS were used to complete the project.
I was bit lucky that the chassis only had minor work.
Cleaned it with high pressure jet washer and treated the bad areas and prepared it for a good paint.
Attached few images of the same.
https://imageshack.com/i/po1hDmaTj
Edited by EAP
You have a 32- 300TDI? They only began production in the mid 90s.
Likely something that started life as a "110" and not really a "Defender" per se
EAP, only the images of the chassis seem to be visible...? :unsure:
Did you need to replace the entire bulkhead?
Hi Everyone
https://imageshack.com/i/po1hDmaTj'>https://imageshack.com/i/po1hDmaTj
When are you planning to sell the 3rd project?
As per RMV records This was a 1952 series and has had lots of changes to its Engine and the chassis was converted to Coil springs at some point.
Yes, All parts were changed as a complete Body and running gear.
Image attached of the XS Bulkhead.
https://imageshack.com/i/pnHPdJ0Wj
More Images to follow.
Edited by EAP
