Fixing Blinking Airbag Indicator On Nissan N16 Or Similar
Martial
After wasting couple of thousand+ rupees for a simple scanning at garages I've found that this simple method do it for you without spending a single cent. Worked perfectly for my Nissan N16.
Hope this will be helpful for anybody else who experience the same problem.
My N16 car has the same problem. Machan can u simply explain it ? I cant understand the Video!
Yes. Sure. (As I remember) following method worked for me.
1. put your key in key hole and turn it until dashboard lights turn on (don't start engine)
2. turn the key all the way off just after dashboard lights turned off (AND BEFORE AIRBAG LIGHT START BLINKING. Don't panic you've few seconds before it starts blinking)
3. repeat this 5 times
That's it. Simple as that.
There is another method posted here. But didn't work for me. You may try it too if above won't work for you.
http://www.mollystropicalplants.com/2012/07/25/resetting-a-nissan-almera-airbag-warning-light/
Please try it and let me know how it goes machan.
