3 answers to this question
What is the year/Engine?
Wht color is the light..
There is a yellow low oil level indicator,
What is the engine oil you use?
Edited by Twin Turbo
:sport-smiley-003: Not bad for a VEHICLE RUN FOR NEARLY A QUARTER OF A CENTURY! :speechless-smiley-003:
If you show this to a Garage, the first thing they'll recommend is an overhaul.which you may or may not need. What ever engine oil you use it will not "grow back" worn components in an engine,
1. Replace the oil pressure switch. Very cheap compared to an overhaul.Remember to replace it with a new aluminium washer and don't over tighten it.
2. Add an oil viscosity additive to the engine ( mix with the oil) - Just ask any Fuel station or spare parts shop. it'l a thick fluid like honey.
Hope for the best and drive in to the sun set! :)
TT.
