rush9975 Posted April 22, 2016 Share Posted April 22, 2016 Has anyone used #M scratch remover product? Is it good enough to scratches? Also I want to know about the pen. Is it really effective? Quote Link to comment Share on other sites More sharing options...
Crosswind Posted April 22, 2016 Share Posted April 22, 2016 All scratch removers work as long as the scratch is only on the paint surface. They can't do miracles. Incidentally, I've seen tubes of vehicle scratch removers. I bought one sometime back and found that all it has, is rubbing compound. Only the price per gram was about 10 times higher than a bottle of 3M compound. Quote Link to comment Share on other sites More sharing options...
Quiet Posted April 24, 2017 Share Posted April 24, 2017 Sorry to bring up an old thread. Does those products on ebay (Pens) work removing clear coat scratch marks? I have some scratch marks on both sides of the bonnet done by my dog. They disappear temporarily if i apply some water or wax (Not deep) but reappear when dry, so im thinking these are clear coat scratches. Quote Link to comment Share on other sites More sharing options...
RWD Posted April 24, 2017 Share Posted April 24, 2017 Quiet- you can get touch up pens from e bay for your 6. They have all the colours and are not costly either. Does a decent job of hiding minor scratches Quote Link to comment Share on other sites More sharing options...
Quiet Posted April 24, 2017 Share Posted April 24, 2017 On 4/24/2017 at 12:00 PM, RWD said: Quiet- you can get touch up pens from e bay for your 6. They have all the colours and are not costly either. Does a decent job of hiding minor scratches Expand Thnx m8 Quote Link to comment Share on other sites More sharing options...
fiat fan Posted April 24, 2017 Share Posted April 24, 2017 (edited) IMO they are crap! what they show on TV does not happen. Its ok for really tiny scratches! Edited April 24, 2017 by fiat fan Quote Link to comment Share on other sites More sharing options...
vishkid Posted April 26, 2017 Share Posted April 26, 2017 Most of the paint pens are crap. If you're not careful with the amount of paint dispensed, you will end up with more visible paint marks compared to the scratch. If those are clear coat scratches (i.e. disappears when wet) and if you're in to DYI, just find some 3000 and 5000 grit good quality sandpaper, wet grind the scratch down (higher grit paper first) and then polish it off. Sounds scary and the interim result - after the sandpapering - is enough to give you a heart attack, but the ultimate result is better than any other process. Only works for clear coat scratches though. I've done it for a newer vehicle which happened to go through some scrubs at yala with long but not deep clear coat scratches and worked a charm. https://www.youtube.com/watch?v=2nYF46P7B2c 1 Quote Link to comment Share on other sites More sharing options...
The Stig Posted April 27, 2017 Share Posted April 27, 2017 Try rubbing some brasso first on a tiny scratch, if it works then rubbing compound is all you need. 2 Quote Link to comment Share on other sites More sharing options...
