Hey guy I've got a Nissan N16 ii (N17) 1.3 Manual 2003.
There was an issue with the ECU and 2 cylinders were not firing properly. The garage told that the ECU is damaged and I replaced it. ( This was about 2 years ago, and the car isn't used much.) I replaced it and it was alright I didn't notice any issues back then. Not sure about fuel economy because I didn't use the car. After the Ecu was replaced the car was left without use for around an year.
Recently I've found out that the ECU is from an Auto version and it gives a P0600 Error when scanned. But when replacing the ECU we tried out different ECUs and the automatic ones didn't even start the car, I thought this was a manual ECU.
However I was wrong, and the car has some performance delay when going at around 3k rpm, for example when accelerating under normal gas the rpm would stop at 3k for around 2 seconds then it would advance higher. And the only way to make it go above 3k sometimes is to downshift and rev harder.
The main issue is that the fuel consumption is higher than normal, I haven't been using this car for a long time (Locked up in a garage at granny's) but when I started using this again (4 months) I felt the fuel consumption is really high even if babied out (6kpl Colombo with AC). The MAF failed and fuel pump failed I replaced both of them as well.
Last week I went to get my emissions certificate and realised the ECO test was failed and the fuel told me theres a lot of fuel wasted. I did tune ups about 2 months back when I started to use this car. But the fuel consumption isn't fixed and the rpm issue either.
Is there a way to get my old Factory ECU fixed so that I can be still using that ECU instead of the Automatic one installed? Is there a trusted place to get this fixed?
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Deeshana
Thank you in advance.
3 answers to this question
