I'm in-need of a TOYOTA IST(NCP60- 2003) ABS Sensor for the right rear wheel.For like , 2 months ago while I was driving,suddenly the ABS & Handbrake indicators on Dashboard were lit up. But after a engine Re-start the indicators was inactive  and showed up again when the car was running. Did a scan and determined that there is a problem with the ABS indicator @ the Right Rear Wheel , which is needed to be replaced.
I have checked with the Toyota Spare Parts, but they only have the Full set which will cost at around 30K LKR. So do help me out with the information on where to buy a Brand new  ABS sensor for the particular model.
Thanks.
5 hours ago, thilinamc said:
Thanks.
Is this the part? Used one will cost you around Rs. 12,000.
Rear wheel sensor is built into the wheel hub and hence you cannot buy the sensor separately. I do not see a point in replacing the whole hub unit with a used one because you would never know the condition of the bearing. If the bearing packs up you will have change the whole unit again. If you are interested PM me to give you a place near Nugegoda area to get the hub changed with a new one.
