Hi All,
I recently bought a J44 4DR5 Jeep. It is not having power steering. And I am willing to keep it's original features. I need to upgrade tire because they are worn-out.
  • Jeep had 15" size rims with radial tire.
  • Later I bought original 4DR5 Rim size 16".
  • Now I am having both 15" & 16" size rims.
  • I found only CE#T tires available in 6.00-16 with bar threads( Calling as Jeep Katta). No way to find out 7.60 15" Tires.
My Questions
  1. Is there any issues with using 6.00-16 tires, instead of 15" size? (Braking, Stability, Comfortably, Noise....)
  2. Is there any other way to find tires with higher width?(Like 7.60..).
  3. I had attached a image bellow. It 's spare wheel is low width tire. What would be the usability of similar kind of tire ? And sizeof the tire?
Thank you
Edited by VishwaR
Better invest in a power steering system if you're going to get fatter tires,:sport-smiley-003: and keep the total height and aspect ratio of the wheel same or you'll be off setting your final derive ratio. giving bad fuel economy with the 4spd 'box.
Edited by Twin Turbo
