sira Posted April 28, 2017 Share Posted April 28, 2017 Dear Friends I brought Suzuki swift 2004 (Japanese) car last week and when i checked with scanner i saw 2 fault code - C1122 which is belongs to EPS .and other one of immobilizer the previous owner said that he change whole rack unit. now when i check this on the web it says the speed sensor signal not comes to EPS. so you have any experience with this issue? other one is the remote key seems not working. i check the circuit board and no luck. how to fix that Thank you sira Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted April 28, 2017 Share Posted April 28, 2017 Just clean the crank speed sensor and see if comes again. I don't think you get CEL indication or an EPS problem right? Quote Link to comment Share on other sites More sharing options...
sira Posted April 28, 2017 Author Share Posted April 28, 2017 On 4/28/2017 at 10:54 AM, Rumesh88 said: Just clean the crank speed sensor and see if comes again. I don't think you get CEL indication or an EPS problem right? Expand No, it only for the scanner Quote Link to comment Share on other sites More sharing options...
