Sorry for being blunt br, everything from the Starship Enterprise downwards has an engine/s.
your car was built in an age where the word 'Tune up; had gone obsolete.
I guess you're wanting to  cure high fuel consumption. you ned to do a complete system check for things like the 02 sensor, which your avg garage can't do.
Start with air filter, new plugs and see what it will do.  Leaving the Dylithium crystals for last.:D
In case of your car being auto, change the ATF.
Edited by Twin Turbo
4 hours ago, Twin Turbo said:
Start with air filter, new plugs and see what it will do.leavingthe Dylithium crystals for last.:D
Hope he doesn't forget to check blinker fluids and Flux capacitor charge.
14 hours ago, Shaa said:
For Mazda bj5p
For something basic like cleaning iacv, EGR, throttle body cleanup, spark plug check, and injector cleaning it would cost around 3000-4500 ish depending on the amount of work that needs to be done. But if you replace any parts like spark plugs that will cost extra.
Start with air filter, new plugs and see what it will do.  Leaving the Dylithium crystals for last.[emoji3]
Fuel consumption actually is not an issue In this vehicle it is doing 16+Km for long distance and 12 to 13 for traffic but the problem is some poping noise coming from airfilter.
