mash1981 Posted July 26, 2017 Posted July 26, 2017 I ve been using this car for about an year now.suddnely this is giving some troubles.When on idle and ac is on car starts to jerk and drop rpm also car doesnt move though i hit the acceleration. Any idea or a good place for a scan or inspection ? Need experts advice Thanks Quote
The Stig Posted July 26, 2017 Posted July 26, 2017 You have an elm adapter? If you do let me know, I will tell you what to do. Sounds like and issue in the maf or tps. Just remove the maf and see if the car runs fine. Maf is located between the air filer and throttle body, this is what it looks like: Quote
mash1981 Posted July 26, 2017 Author Posted July 26, 2017 Thanks bro i dont have a elm code reader.i sent you a PM Quote
kira Posted July 26, 2017 Posted July 26, 2017 most likely the MAF. had a similar issue with my BJ5W and turned out to be MAF. replacing would be better than trying to clean. 1 Quote
mash1981 Posted July 26, 2017 Author Posted July 26, 2017 most likely the MAF. had a similar issue with my BJ5W and turned out to be MAF. replacing would be better than trying to clean. Thanks bro.thinking of taking it to a mechanic on saturday.from where will i be able to buy a MAF? Quote
Rohnd Posted July 27, 2017 Posted July 27, 2017 18 hours ago, mash1981 said: Thanks bro.thinking of taking it to a mechanic on saturday.from where will i be able to buy a MAF? MAF can be easily cleaned with an electronic cleaning aerosol fluid, It is a delicate,but a simple job. If replace, should only be replaced with a genuine one. How about throttle body cleaning !, You have to check that also. Your car fault attributes so many other factors too, such as the ignition system & spark plugs etc. 1 Quote
mash1981 Posted July 27, 2017 Author Posted July 27, 2017 MAF can be easily cleaned with an electronic cleaning aerosol fluid, It is a delicate,but a simple job. If replace, should only be replaced with a genuine one. How about throttle body cleaning !, You have to check that also. Your car fault attributes so many other factors too, such as the ignition system & spark plugs etc.Thanks.recently i did a tune up.Throttle body was cleaned at that time.shall ido a full scan first?im clueless where to start? Quote
LashNeo Posted July 28, 2017 Posted July 28, 2017 (edited) Idling issues in a BJ5P can occur due to several reasons; Some of the reasons i can think of are as follows; Issue with the MAF sensor Issue with the CAM position sensor Busted Ignition coil packs Busted spark plugs Vacuum leaks Loosened Air filter Since you have done a tune up recently; your spark plugs must have been already checked. Therefore, i would suspect it would be related to something else. I think the best thing would be to perform a scan first. Are you nearby colombo? if so; the best place to do this would be Mazna motors. They might diagnose the issue by experience even without scanning. Edited July 28, 2017 by LashNeo 1 Quote
LashNeo Posted July 28, 2017 Posted July 28, 2017 (edited) Just now noticed.. Am i seeing a loosened connection in the highlighted location? Can you please check on this first? might be a Vacuum leak. Just push the hose forward to fasten it. Edited July 28, 2017 by LashNeo Quote
The Stig Posted July 28, 2017 Posted July 28, 2017 Just now noticed.. Am i seeing a loosened connection in the highlighted location? Can you please check on this first? might be a Vacuum leak. Just push the hose forward to fasten it.Nope it's not unplugged, there is a sponge on that hose. It's the hose to the carcoal cannister. 2 Quote
mash1981 Posted July 28, 2017 Author Posted July 28, 2017 Just now noticed.. Am i seeing a loosened connection in the highlighted location? Can you please check on this first? might be a Vacuum leak. Just push the hose forward to fasten it.Thanks bro.thinking of taking it to mazna. Quote
similarnames Posted July 30, 2017 Posted July 30, 2017 (edited) Do yourself a favor (Before taking your car to so-called Mazda experts, go to a Recon Spare Parts shop and get the part. Try to get the entire throttle body (Recon) and put everything back, It will cost you around 8K-10K for the throttle body with sensors. I believe it was VTCS valve or something. ZL-VE repair manual is a bitch to comprehend. Edited July 30, 2017 by similarnames 1 Quote
mash1981 Posted July 31, 2017 Author Posted July 31, 2017 8 hours ago, similarnames said: Do yourself a favor (Before taking your car to so-called Mazda experts, go to a Recon Spare Parts shop and get the part. Try to get the entire throttle body (Recon) and put everything back, It will cost you around 8K-10K for the throttle body with sensors. I believe it was VTCS valve or something. ZL-VE repair manual is a bitch to comprehend. Hmmm well thats a good advice Quote
mash1981 Posted July 31, 2017 Author Posted July 31, 2017 Scanned it !!!! MAF replaced!!! Lets run and see.have a stable idle than before. Quote
LashNeo Posted July 31, 2017 Posted July 31, 2017 On 7/28/2017 at 7:48 PM, The Stig said: Nope it's not unplugged, there is a sponge on that hose. It's the hose to the carcoal cannister. Yep. You are correct. It’s the sponge. I honestly thought the hose was loose. This happened to me some time back. The car was stalling in the middle of the road suddenly. There was no hesitation from the engine but the engine was going off on idle from time to time. While taking a look under the hood noticed that this hose was loose and everything was back to normal once it was connected. I couldn’t recall that there was a sponge attached to the hose. After seeing your comment; looked at the hose in my car again and noticed that there was a sponge but it was slipped towards the other end. Probably the reason for the disconnection of the hose as it helps to grip the hose against the other hose near it. Quote
LashNeo Posted July 31, 2017 Posted July 31, 2017 3 hours ago, mash1981 said: Scanned it !!!! MAF replaced!!! Lets run and see.have a stable idle than before. @mash1981 Glad to hear that you sorted out the issue. How much did it cost for the MAF? 1 Quote
mash1981 Posted July 31, 2017 Author Posted July 31, 2017 36 minutes ago, LashNeo said: @mash1981 Glad to hear that you sorted out the issue. How much did it cost for the MAF? Its a used.got it for 4.5k Quote
Pradeeppw Posted December 28, 2017 Posted December 28, 2017 (edited) I have a car auto.mazda bj5p Now blinking hold light and giar not funtion only 3 and not going od Pls explan .. Edited December 28, 2017 by Pradeeppw Quote
mash1981 Posted January 8, 2018 Author Posted January 8, 2018 On 28/12/2017 at 8:53 PM, Pradeeppw said: I have a car auto.mazda bj5p Now blinking hold light and giar not funtion only 3 and not going od Pls explan .. Go to nilwala or mazna and check your gear box.did you scan the vehicle ? Quote
Rohnd Posted January 9, 2018 Posted January 9, 2018 On 12/28/2017 at 8:53 PM, Pradeeppw said: I have a car auto.mazda bj5p Now blinking hold light and giar not funtion only 3 and not going od Pls explan .. This is a most common fault on Mazda BJ. Probably due to filling of incorrect ATF fluid /poor maintenance etc. and sometimes need a replacement of the gear box. Quote
chathurai Posted January 17, 2019 Posted January 17, 2019 On 1/9/2018 at 8:48 AM, Rohnd said: This is a most common fault on Mazda BJ. Probably due to filling of incorrect ATF fluid /poor maintenance etc. and sometimes need a replacement of the gear box. can you recommend some place to buy gearbox for my bj5w Quote
Liam Bennett Posted October 24 Posted October 24 Hi everyone. Need abit of help on the timing marks for the bj5p mazda engine. It is the vvt configuration and am abit lost Quote
