ANDREW FERNANDO Posted August 4, 2017 Share Posted August 4, 2017 I have a Land Rover series two ,I want to completely restore my Land Rover into a defender td5 ,does anyone know whether it's legal to do it and does the rmv allow this kind of convertion Quote Link to comment Share on other sites More sharing options...
tiv Posted August 5, 2017 Share Posted August 5, 2017 If you try to do this mechanically u will end up with a Frankenstien with no value, mostly illegal, plenty on the roads now covered up with E*-XXXX numbers If you try to use your number with a real defender black import, again no value and totally illegal, yet plenty on the roads Buy with the new laws spooling up you are likely to get convicted eventually, thus avoid the above If you want a real defender, better off buying a real chassis with reg and build it ground up, Will be solid and will have the value with time. Remember LRs are quite un-reliable unless you do them up properly, and expensive But now trends are picking up where people restore series IIs with better running gear retaining the same look and chassis more or less a restomod as defenders are kinda all over now and series IIs are getting rarer as people tend to chop them up. Quote Link to comment Share on other sites More sharing options...
