HI ,
I'm having a 2014 axio hybrid and i can see the below error message while stopping the car only. does any body knows what this means highly appreciate your thought.
Replace the battery on your key???
'Key Battery Remaining Little' is the direct translation from Japanese to English as per the google translate app.
you can scan any text. It's a must have if you're using a modern JDM vehicle unless you can read Japanese.
Edited by matroska
Don't go to TL to get key fob battery replaced. They will probably charge 2000+ for the job.
Battery is user replaceable and won't take more than 30 seconds for the job. Just search in youtube if you don't know how to open they key.
Just tried the OCR and Google translation:
According to it:
"Key battery remaining a little"
May be your key battery running out soon! :rolleyes:
Edited by gNaveendra
language clear
Actually it says ur smart key battery is weak.
Replace the battery wont cost u more than Rs. 150 for battery. Can do it by yourself as well.
According to it:
Thanks to all who replied. :)
  • 1 year later...
HI ,
I'm having a 2014 axio hybrid and i can see the below warning  message while closing doors of the car sometimes. does any body knows what this means highly appreciate your thought.
AND REQUEST GIVE REMEDIES FOR IT. THANKS
Edited by JayaR
17 minutes ago, JayaR said:
HI ,
Key Not Found.
17 hours ago, JayaR said:
HI ,
Just Replace The Key Battery, It will Just go off once u replace
