SharpClaws Posted October 4, 2017 Posted October 4, 2017 ok so i'm currently working on installing speeduino ecu (same as a megasquirt) to my bmw e34 m40 engine. i will post more info later but here is some videos First Start ! Launch control action Driving around Quote
vag2 Posted October 4, 2017 Posted October 4, 2017 5 hours ago, SharpClaws said: installing speeduino ecu could you elaborate?by "installing" you mean Swapping ECU or Swapping Software? Quote
SharpClaws Posted October 5, 2017 Author Posted October 5, 2017 Remove stock ecu and stock flap type air flow sensor and using ignition coils instead of the distributor. Quote
