Ted Posted December 10, 2017 Posted December 10, 2017 (edited) Hi all, I noticed white smoke in cold start of my car. During this white smoke out water too coming out from exhaust pipe. Also I experience the exhaust is sulpher like odour. I also feel like I need to accelerate more than that of a normal car to go for higher speeds. Oil also reduced for around every 3000kms. Could you please advice me, 1) Is piston ring check enough for diagnosis? 2) exact reason that you think. Your comment is highly appreciated. Edited December 10, 2017 by Ted Quote
MV-5 Posted December 11, 2017 Posted December 11, 2017 (edited) probably the blown head gasket. how is the coolant/water level in the tank? Edited December 11, 2017 by MV-5 1 Quote
dhanuFB15 Posted December 27, 2017 Posted December 27, 2017 (edited) How abt mileage? It's due to wear pistons and rings of engine oil mixing to the burning chamber, Better to use 15w-40 oil and keep change oil frequently ( 3000 kms or 6 month) can running engine another days Edited December 27, 2017 by dhanuFB15 1 Quote
MV-5 Posted December 27, 2017 Posted December 27, 2017 (edited) 20 minutes ago, dhanuFB15 said: How abt mileage? It's due to wear pistons and rings of engine oil mixing to the burning chamber, Better to use 15w-40 oil and keep change oil frequently ( 3000 kms or 6 month) can running engine another days what you are saying is , due to worn out piston rings when the vehicle was overnight parked, engine oil comes into combustion chamber and those accumulated oil can make white smoke in cold start (in the morning probably) and even make water coming out from the exhaust pipe. I can not understand, how is it possible? please elaborate more. Edited December 27, 2017 by MV-5 Quote
Ted Posted December 27, 2017 Author Posted December 27, 2017 6 hours ago, dhanuFB15 said: How abt mileage? It's due to wear pistons and rings of engine oil mixing to the burning chamber, Better to use 15w-40 oil and keep change oil frequently ( 3000 kms or 6 month) can running engine another days Yes..untill I check for engine and do the needful..started to go for 15w-40... engine is fine other than this lil white smoke at the vehicle start of the day, sudden pick-up is very lil bit weak and engine raising noise is very lil bit discrete.. Quote
Ted Posted December 30, 2017 Author Posted December 30, 2017 On 12/27/2017 at 12:56 PM, dhanuFB15 said: How abt mileage? It's due to wear pistons and rings of engine oil mixing to the burning chamber, Better to use 15w-40 oil and keep change oil frequently ( 3000 kms or 6 month) can running engine another days Milage is 278000 km Quote
Rohnd Posted December 30, 2017 Posted December 30, 2017 (edited) 14 hours ago, Ted said: Milage is 278000 km Wear in Valve Stem Seals is another possibility for this. Edited December 30, 2017 by Rohnd Quote
