amsandun Posted December 12, 2017 Share Posted December 12, 2017 Hello guys, I am looking to buy my first car and going through many choices. I just came to know some Prius 2nd Gen models are available closer to my budget (3.3 - 3.5 mn). Since the car is manufactured in 2008/2009 and might have been used for nearly 10 years, is it advisable to go for it ? I hear it has good fuel economy though. And what are the main considerations to look out for? (Hybrid Battery etc...) Thanks in Advance. Sandun. Quote Link to comment Share on other sites More sharing options...
carbuddy Posted December 12, 2017 Share Posted December 12, 2017 Here is my experience (Anyway you need to check service history, etc as a normal vehicle), Do a scan from a good service location (With a proper device) Check voltage of HV battery cells, Report should show nearly same voltage for all cells. Depending on the mileage you may need to check whether inverter pump is replaced or not (as i can remember brand new one is around 18k - Not from toyota lanka). (milage 80k+) Other than that there is no any issues. 1 Quote Link to comment Share on other sites More sharing options...
ajm Posted December 12, 2017 Share Posted December 12, 2017 Ask the owner and take it to Toyota Lnka for a scan.I doubt any other places have proper Toyota scanners that can capture all errors especially related to the additional hybrid components ageing 10 years under our harsh weather. 1 Quote Link to comment Share on other sites More sharing options...
amsandun Posted December 13, 2017 Author Share Posted December 13, 2017 On 12/12/2017 at 12:29 PM, carbuddy said: Here is my experience (Anyway you need to check service history, etc as a normal vehicle), Do a scan from a good service location (With a proper device) Check voltage of HV battery cells, Report should show nearly same voltage for all cells. Depending on the mileage you may need to check whether inverter pump is replaced or not (as i can remember brand new one is around 18k - Not from toyota lanka). (milage 80k+) Other than that there is no any issues. Expand Thanks for the info carbuddy.. So do you mean that after about 80k mileage, inverter pump has to be replaced? Bcz I am not well-versed on the subject, is the inverter pump used to charge the car battery? Is there any specific voltage value I should look for in the cells? Quote Link to comment Share on other sites More sharing options...
carbuddy Posted December 14, 2017 Share Posted December 14, 2017 On 12/13/2017 at 10:14 AM, amsandun said: Thanks for the info carbuddy.. So do you mean that after about 80k mileage, inverter pump has to be replaced? Bcz I am not well-versed on the subject, is the inverter pump used to charge the car battery? Is there any specific voltage value I should look for in the cells? Expand Normally this is coming around 80k mileage. But it could be vary (in most case if ODO meter is not showing the correct mileage ) Inverter Water Pump is used to pump inverter cool-lent needed for the Inverter. As i know there is no any direct relationship with battery. It is just a for cooling purpose. Regarding the voltage: it should have nearly the same value, but actual figure will be vary depending on the battery charge level. For example if battery is fully charged it may be 12.45 for all, if battery charge level is low at the time you take the report it could be 10.56 for all. [Note these are as example figures i cant remember what was there in my actual report ]. The reason for this is, if any of cell have different voltage (probably a low value, which is a bad cell) then it could result to weak other cells as well (means whole battery will be in bad condition). So if the report have same value or nearly the same value then it is a good one. Quote Link to comment Share on other sites More sharing options...
