Niwantha2007 Posted January 28, 2018 Posted January 28, 2018 hi I have BJ3P 2001 and there is problem in distriburor .Any place to buy it and how much I need to spent Quote
1 Niwantha2007 Posted January 28, 2018 Author Posted January 28, 2018 What you feel when the engine is running.?I newly brought this car, I don't have history. and when the idling there is mis and suddenly nock is coming.and when the accelarating mute the engine. I doubt whether it is distributor, because why only third cylinder not function. How about, test the compressure Quote
0 Niwantha2007 Posted January 28, 2018 Author Posted January 28, 2018 hi I have BJ3P 2001 and there is problem in distriburor .Any place to buy it and how much I need to spent Car model is Mazda Familia, 2001 BJ3P 1300cc Quote
0 Niwantha2007 Posted January 28, 2018 Author Posted January 28, 2018 Car model is Mazda Familia, 2001 BJ3P 1300ccit is ok used one. Quote
0 Rohnd Posted January 28, 2018 Posted January 28, 2018 13 minutes ago, Niwantha2007 said: 14 minutes ago, Niwantha2007 said: Car model is Mazda Familia, 2001 BJ3P 1300cc it is ok used one. Try used parts shops around Dehiwala area. What is the actual problem ?. If it is the Distributor Cap or Rotor , those may be available as new parts. Why not suspect ignition wires ? Quote
0 Niwantha2007 Posted January 28, 2018 Author Posted January 28, 2018 Try used parts shops around Dehiwala area. What is the actual problem ?. If it is the Distributor Cap or Rotor , those may be available as new parts. Why not suspect ignition wires ?thanks,I did engine tuneup & checked wires too. Technician said that the third cylinder not function. and I verify this eith another technician. both confirm that hole distributor should replace. Quote
0 Rohnd Posted January 28, 2018 Posted January 28, 2018 2 minutes ago, Niwantha2007 said: thanks, I did engine tuneup & checked wires too. Technician said that the third cylinder not function. and I verify this eith another technician. both confirm that hole distributor should replace. What you feel when the engine is running.? Quote
0 PerfMad Posted January 28, 2018 Posted January 28, 2018 41 minutes ago, Niwantha2007 said: 1 hour ago, Rohnd said: What you feel when the engine is running.? I newly brought this car, I don't have history. and when the idling there is mis and suddenly nock is coming.and when the accelarating mute the engine. I doubt whether it is distributor, because why only third cylinder not function. How about, test the compressure could it be due to a timing issue? Quote
0 Rohnd Posted January 29, 2018 Posted January 29, 2018 On 1/28/2018 at 6:14 PM, Niwantha2007 said: On 1/28/2018 at 5:32 PM, Rohnd said: What you feel when the engine is running.? I newly brought this car, I don't have history. and when the idling there is mis and suddenly nock is coming.and when the accelarating mute the engine. I doubt whether it is distributor, because why only third cylinder not function. How about, test the compressure Better to check the Distributor cup for any micro cracks internally also wire connections to third cylinder with wire resistance measure (as you said) before proceeding with the replacement with whole distributor unit. A test about the compression is also a possible clue. but beyond and not related to an ignition fault. Quote
0 Niwantha2007 Posted January 29, 2018 Author Posted January 29, 2018 Better to check the Distributor cup for any micro cracks internally also wire connections to third cylinder with wire resistance measure (as you said) before proceeding with the replacement with whole distributor unit. A test about the compression is also a possible clue. but beyond and not related to an ignition fault.Thanks,there are cracks in rotor arm and I am planning to check with new rotor arm , rotor cup & wires.and I have another clue when engine temparatue saturate mis is getting worst but when high rpm is getting better Quote
0 Niwantha2007 Posted February 13, 2018 Author Posted February 13, 2018 Thanks,there are cracks in rotor arm and I am planning to check with new rotor arm , rotor cup & wires.and I have another clue when engine temparatue saturate mis is getting worst but when high rpm is getting betterI did change ignition arm but same result.Finally I send car to the Mazda work shop and they have changed the petrol pump and the air hose and problem solved.Tank you verymuch .Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk Quote
Niwantha2007
hi
10 answers to this question
