May 8, 20188 yr Dear Friend, Normally Toyota Axio Hybrid, there is no spare wheel. Only have Tyre restoration liquid and a gadget. Any one have a experience in using that and is it effective or better to have a spare wheel at our cost ?
May 8, 20188 yr it is effective for small punctures. However you run the risk if tyre gets cut or if the puncture hole is largeย
May 8, 20188 yr I think its better to have a spare wheel. One day when I drove home I noticed my left rear tire was flat, I used the tire restoration kit and it held up for about 6 months. But now its starting to loose pressure in small amount. The instructions clearly states that using the restoration kit is just a temporary fix and to get the tire fixed properly asap. My bad for not following the instructions.ย
May 8, 20188 yr Make it a point to inspect tires once in every month or so as a preventive measure. Within course of last one year ย periodย I found three nails stuck in the tires but only one needing a puncture repair but that too was done in advance. If not for the inspection I could have easily got into trouble on the road.ย
May 9, 20188 yr On 5/8/2018 at 7:19 PM, asrock said: I think its better to have a spare wheel. One day when I drove home I noticed my left rear tire was flat, I used the tire restoration kit and it held up for about 6 months. But now its starting to loose pressure in small amount. The instructions clearly states that using the restoration kit is just a temporary fix and to get the tire fixed properly asap. My bad for not following the instructions.ย Did you get a spare wheel machan? I remember you looking for one. Is it practical tugging that along in the boot?ย
May 9, 20188 yr No machan, still looking for one. The axio has the spare wheel well in the boot so no problem storing it.ย ย
