from the first look this might look like a electrical problem but its NOT
so my father inlaw has a FB 15 which the rear passenger door locks are somewhat sketchy. they locks fine when the lock key is pressed on the sec system, but the locks only partially opens when unlocked. so even though the front are unlocked the rear doors are partially unlocked.
so last week i dismantled the doors and suspected that there might be obstructions to moving parts so cleaned the mechanical parts, lubricated them but same result.
then i disassembled the sealed lock motor mechanism as well cleaned, greased and fitted with no change.
Disassembled it again just to see if anything is stuck. the spring that hold the big gear wheel in the center position got loose when i closed the two covers of the assy, just being curious i left it like that and fixed everything back. so now the main gearwheel which is connected to the motor is free to rotate when motor is powered without the tension of the spring.. surprisingly the auto lock was working fine afterwards.
My question is for anyone that is familiar with the mechanism. now with the motor mechanism and the gearwheels inside of the sealed unit is free from the spring tension, will it create any other problems due to the removal of the spring tension? the spring is there for a reason neh??
PS-i did the same thing to the other side door and it works fine as well....
Is there an alternative to the Maruti 800? A friend of mine is looking for an extremely cheap to run and fix car for around 1.5M. While I do advocate old Japanese cars in that budget - if his need is basic A-B motoring at the lowest possible cost - maintenance wise and with fuel - is there any other option that I am forgetting?
Does anyone know how exactly this is supposed to work? They haven’t really started brand new imports again right?
Pricing seems relatively fine in the grand scheme of things, given how 10/15 year old cars are still pretty expensive in our market
A guy advertises a mileage blocker on the quick site saying that his device blocks the vehicle mileage from changing on the odometer. Is it legal to advertise stuff like this?
Bought a 2007 (Reg 2011) Vitz SCP90 (Mileage 180K+) for the family (will be used by my father). Seems to be in good condition but had some new owner repairs/replaces done to have a free mind.
charithtg
4 answers to this question
