Nicknacks Posted May 20, 2018 Share Posted May 20, 2018 Can a defective coolant temperature sensor in a Nissan FB14 Sunny with a GA15DE engine cause the vehicle to hard start when the engine is cold? Quote Link to comment Share on other sites More sharing options...
Davy Posted May 20, 2018 Share Posted May 20, 2018 Yes. Among many other possible causes. One of the inputs to the ECU to determine the proper air to fuel mixture is the ECT (Engine Coolant Temperature) sensor reading. Bad sensor means inaccurate values. This means the proper air to fuel mixture doesn't reach the cylinders. The car might not start due to this. Get the ECT sensor tested. 1 Quote Link to comment Share on other sites More sharing options...
Nicknacks Posted May 20, 2018 Author Share Posted May 20, 2018 Thanks Davy ..will have it tested. Quote Link to comment Share on other sites More sharing options...
gNaveendra Posted May 20, 2018 Share Posted May 20, 2018 On 5/20/2018 at 4:12 AM, Davy said: Yes. Among many other possible causes. One of the inputs to the ECU to determine the proper air to fuel mixture is the ECT (Engine Coolant Temperature) sensor reading. Bad sensor means inaccurate values. This means the proper air to fuel mixture doesn't reach the cylinders. The car might not start due to this. Get the ECT sensor tested. Will this affect the starting/cranking? Quote Link to comment Share on other sites More sharing options...
Davy Posted May 20, 2018 Share Posted May 20, 2018 On 5/20/2018 at 1:09 PM, gNaveendra said: Will this affect the starting/cranking? Expand The starter motor is not affected, so it will crank the engine as normal. Quote Link to comment Share on other sites More sharing options...
Mohamed Shafraz Mohamed Nisthar Posted August 26, 2024 Share Posted August 26, 2024 temperature sensor serial number Quote Link to comment Share on other sites More sharing options...
