Darshana123 Posted May 28, 2018 Share Posted May 28, 2018 I have noticed a slight vibration in my toyota vitz 2017 model 1000cc car when car is in "D" or "R".same time I noticed a vibration from dash board as well. is it normal for toyota vitz?if it is a problem what is the solution for the matter? 1 Quote Link to comment Share on other sites More sharing options...
0 Twin Turbo Posted May 28, 2018 Share Posted May 28, 2018 HI and welcome. Your prob was just discussed here.just chk previous posts. TT. Quote Link to comment Share on other sites More sharing options...
0 Darshana123 Posted June 8, 2018 Author Share Posted June 8, 2018 Thanks for your reply. That thread does not provide a good answer for my vehicle issue. My one is 2017 model one and it vibrates when car is stopped in d and r mode. At the same time steering wheel side dash board part starts to vibrate and when i shift the gear to N both vehicle vubration and dash board vubration sound reduces gradually. I understood that vibration is a commen issue in 3cylinder engines. But what i want to know is whether this vibration issue causes the vibartion/rattling noise in dash board when car is stopped in d mode or r mode. If it is not normal how to resolve the matter Quote Link to comment Share on other sites More sharing options...
0 Crosswind Posted June 8, 2018 Share Posted June 8, 2018 Most probably have a broken engine mount. Bit unusual for a new car but you never know with these grey imports. Show it to a good garage. 1 Quote Link to comment Share on other sites More sharing options...
0 ghostwriter Posted June 9, 2018 Share Posted June 9, 2018 (edited) have you tried switching off the AC while the car is vibrating? that way, may be you can identify if it has got a faulty idle up sensor? (I'm just guessing from a previous experience I had). If the vibration is not there in the N mode it might not be the engine mount no? some issue with the transmission system like gearbox mounts? Best bet is to get it inspected by a qualified mechanic ?♂️ Edited June 9, 2018 by ghostwriter Quote Link to comment Share on other sites More sharing options...
Darshana123
4 answers to this question
