Head Light Repair
SMadu
Hello,
I need to get repaired the head lights of my car. I checked for a solution in this forum but could not find the exact thing what I'm looking for.
Even though I found many posts regarding the head lights cleaning, what I need to get done is to repair the head lights. The reason is after running in rain I can see the vapor /  water drops at the inner surface of the headlight cover.
Could someone recommend me a better place to get this repaired.
Vehicle : Honda Civic ES8 Facelift model.
Sorry if I'm re-posting something which had already being discussed here. If so, please direct me to that post
If there is a crack on the lens (even a hairline one) then you are pretty much out of luck.
You might want to check if any of the rubber grommets/seals are undone or worn out. If worn out...try to get the grommets/seals replaced. If the back body of the headlight is broken...then some people fix it up with various materials (seen people use everything from no-leak to silicone filler). If the seals are worn out then you can use the same to seal it up.
I had a similar issue in one of my ES8s headligh assemblies, there are still some hairline cracks on the lenses, but a place at Nedimala junction fixed my problem by taking it all apart and re-sealing the unit. Afterwards they applied a wax on the lens to seal the cracks. I know its a temp solution, but it has held up for 6 years now. They charge around Rs1500 per light
Edited by rukmaldk
  • 1 year later...
Hello all
I just bought a Prado 150 - 2104 model with teardrop set of headlights.
It has the same issue. In one of the headlights , there is little bit of  vapor /  water drops at the inner surface of the headlight cover. There is no any crack visible.
Pls let me know a reliable place. I want a good place knowing that they will disassemble the headlight for the job hence needs to be in safe hands.
@ rukmaldk - pls let me have contact number of the place you visited for the job.
The impacted area is marked in red below.
Pls help
  • 2 years later...
20 hours ago, anela1887 said:
I'm sorry to hear it mate! Hope the damage is not too serious.
Hey man, I really hope the damage is not significant! From my personal experience, I may say that fixing a damaged headlight may unexpectedly transform into a very complicated task (lol). Anyway, I think you should seek some professional assistance from a specialist. Luckily, there are many of them around, and they don't charge a fortune. A couple of months ago, the guys from https://www.vont.com/product/vont-car-smart-strip-light/ installed a smart strip light in my car. Coincidentally, they were also able to fix my headlight issue! Good luck.
Edited by Bernd1Arce
