Toyota Starlet Reflect X (EP91-4E-FE) Air conditioner
kneth
Hi guys. I need some advice!
I have the above model car and my AC is not cooling enough. All components are fine, but the thermostat cuts off at 10 degrees Centigrade.
The thermostat on this car is not adjustable.
Please advice me on the following...
1. What is the recommended temperature the thermostat should cut off?
2. How can I drop it to about 5 - 1 degrees Centigrade?
Thank you in advance for your advice.
Is the car equiped with both a/c and econ modes? Is the thermostat cutting off even with full blower speed?
Yes, the  car is equipped with both a/c and econ modes. Yes, the ac cuts off at around 10 degrees C even with full blower speed.
  • 10 months later...
Recently bought an EP91 and have no expertise on aircon so take this with a grain of salt.
If it cuts off at 10 centigrade sounds like it cuts off at the level the ECON is supposed to cut off.
While I didn't have this problem in a car my airconditioner once cut off because the blower wasnt working properly therefore it cooled the AC unit at a far cooler temperature than the cabin, which made it cut off after a while.
Regardless hope you fixed it
MC
  • 3 years later...
MC
Thank you for your response. I still could not solve the problem.
