I bought a reconditioned engine and replaced it at Sunil Motors Boralesgamuwa. After two days of the replacement, in the morning I went to the emission and it was passed. Then I waited around at home 1hr and started to go to a near by place. After around 1.5km the car was suddenly stopped.
There was an AC Idle issue due to Sunil Motor mechanic adjusted wrongly. I adjusted normal idle correctly but couldnot adjust AC idle valve since I had no proper allen key for that. So for all earlier trips I did not switch in AC. For this small trip I had to use AC since my wife was with me in car. When idling engine is stalling since not enough air. Kind of this happened before the sudden stop. I tried several times to start but engine rpm rises comes back to zero. Forcefully I peddled accelerator and got into a nearby spaced area. While I was forcefully peddling I engine gave a huge thud noise.
Mechanic came and tried to rotate the engine. Engine locks at one point when turning.
I still cannot think what happened. Because,
1) Engine was a very good one since we carefully inspected rubber hoses, sensors, coolant passages, cam shafts, even the thermostat was like a brandnew one.
2) After the replacement I drove around 50kms and nothing was wrong in the engine. If mechanic had misaligned the timing belt this could have happened sooner. Am I ryt?
Anyway mechanic will start to dismantle engine on tuesday.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Ted
Hi All,
There was an AC Idle issue due to Sunil Motor mechanic adjusted wrongly. I adjusted normal idle correctly but could not adjust AC idle valve since I had no proper allen key for that. So for all earlier trips I did not switch in AC. For this small trip I had to use AC since my wife was with me in car. When idling engine is stalling since not enough air. Kind of this happened before the sudden stop. I tried several times to start but engine rpm rises comes back to zero. Forcefully I peddled accelerator and got into a nearby spaced area. While I was forcefully peddling I engine gave a huge thud noise.
Highly appreciate your comments.
3 answers to this question
