Also i couldn't finds OBD 1 SRS,ABS and Tyre pressure indicators fault codes list.
Reading ABS codes
Turn the ignition on.
Connect the leads "TC" and "E1" of the DLC1 connector.
Remove the jumper from the "WA" and "WB" terminals.
After 4 seconds, read the code for the number of flashes of the ABS indicator.
Remove the jumper from the terminals "TC" and "E1".
Set the jumper on the "WA" and "WB" terminals.
Resetting ABS codes
Bring the conclusions of "TC" and "E1"
Press the brake pedal eight or more times in the interval of three seconds.
The indicator should output the normal code (flashing 2 times per second).
Turn the ignition off.
Make sure that the ABS indicator goes out.
The SRS (Toyota) self-diagnosis codes are read in the same way as the number of "SRS" indicator flashes with the closed terminals "TC" - "E1". Erasing codes must occur when the ignition is switched off. If the codes are saved, a cleaning procedure must be carried out.
The tire pressure monitoring system provides its own self-diagnosis. The codes are read in the standard way for Toyot's by the number of indicator flashes with the ignition on and the closed terminals "TC" and "E1". Removal of codes is carried out in the same way as deleting the codes of the ABS system.
I'm going to buy a car in SL for 2 mil while being in Germany. Then I'm going to put up a public raffle draw and pick one lucky winner to gift that car when I have 600 participants registered in the raffle draw. Registration fee for each participant is Rs. 5000/-
Why didnt I think of this before
So for a spirited convo like this old times; ?BYD
My father has gone ninja about getting one, despite being the new hype/fad here these are common across the world and I've seen a few cross 100,000km in Nepal and Australia.
Seal - Looks nice, very premium interior but too low for my applications
Sealion - Very Premium, feels very well built, BUT that 1.5L on that reasonable chunk of car with a measly 18KW battery seems like a recipe for trouble, incase they sink in value at least the fuel economy must justify that (They say it's a BYD engine - though the lore is it is a hyundai engine)
Atto 3 - Most sold from their lot apparently, common af, Seems to be the best bang for buck IMHO, Its electric since BYD is famed for that, Interior is kinda good, the thing is larger than a vezel but not too large like the Sealion, cheap mobility I guess with less things to go wrong
Dolphin, almost a smaller atto and again too car like and not suited for my application.
JK nailed it on the price and distribution but the only guaranteed thing here is the lot are gonna muck up the aftersales. The Kandy center staff behave like the crew from a Govt. post office.
What are your thoughts and opinions? Could this be the next Wagon R or is this a passing fad like the Micros of 2000s-2010s?
I have an empty parking slot at home previously occupied for 6 years by the starlet and 3 months by an AD wagon -what would be a bang-for-the-buck fun shitbox? Preferably auto as I live in a crowded suburb that has sapped the joy of stick shift out of my system.
Asanka Pubudu
Is this method right or wrong?
Reading ABS codes
Resetting ABS codes
8 answers to this question
