Asanka Pubudu Posted April 24, 2020 Posted April 24, 2020 There is about one minute delay in gear shifting at first start.It is an automatic transmission (Toyota corolla AE110 yom-1997). What should I do? Quote
0 Ted Posted April 24, 2020 Posted April 24, 2020 2 hours ago, Asanka Pubudu said: There is about one minute delay in gear shifting at first start.It is an automatic transmission (Toyota corolla AE110 yom-1997). What should I do? Dear @Asanka Pubudu, Check following tests and based on results of each test, I am giving tips you which should focus on ( 90% likely). 1) Testing from N to R 1.1) By pressing break pedal, shift selector from "N" to "R". 1.2) Gear should be changed within 1.2 seconds. If NOT, possible causes, A ) Too low pressure in oil lines. B ) Wear of the reverse clutch. C ) Wear of the break of the first gear and reverse gear. D) The clutch of the lower planetary series if faulty. 2) Testing from N to D 2.1) By pressing break pedal, shift selector from "N" to "R". 2.2) Gear should be changed within 1.4 seconds. If NOT, possible causes, A ) Too low pressure in oil lines. B ) Wear of the forward clutch. C) The freewheel clutch No. 2 and the Clutch of the lowering planetary series are faulty. Above are the recommendations of Toyota. So first off check whether your oil level is OKAY and Oil age is within the service period. If not either you will have to repair the gear or buy a reconditioned one. 1 Quote
0 tilvin Posted April 24, 2020 Posted April 24, 2020 7 hours ago, Asanka Pubudu said: There is about one minute delay in gear shifting at first start.It is an automatic transmission (Toyota corolla AE110 yom-1997). What should I do? When did you change the oil? Is it long time? 1 Quote
0 Asanka Pubudu Posted May 10, 2020 Author Posted May 10, 2020 On 4/24/2020 at 3:22 PM, Ted said: Dear @Asanka Pubudu, Check following tests and based on results of each test, I am giving tips you which should focus on ( 90% likely). 1) Testing from N to R 1.1) By pressing break pedal, shift selector from "N" to "R". 1.2) Gear should be changed within 1.2 seconds. If NOT, possible causes, A ) Too low pressure in oil lines. B ) Wear of the reverse clutch. C ) Wear of the break of the first gear and reverse gear. D) The clutch of the lower planetary series if faulty. 2) Testing from N to D 2.1) By pressing break pedal, shift selector from "N" to "R". 2.2) Gear should be changed within 1.4 seconds. If NOT, possible causes, A ) Too low pressure in oil lines. B ) Wear of the forward clutch. C) The freewheel clutch No. 2 and the Clutch of the lowering planetary series are faulty. Above are the recommendations of Toyota. So first off check whether your oil level is OKAY and Oil age is within the service period. If not either you will have to repair the gear or buy a reconditioned one. I already changed the oil but still have the same problem in first start.when it heated disappear the problem Quote
0 Ted Posted May 10, 2020 Posted May 10, 2020 57 minutes ago, Asanka Pubudu said: I already changed the oil but still have the same problem in first start.when it heated disappear the problem Did you check all the tests? Is delay there for all tests? Quote
0 Devinda_Z Posted May 11, 2020 Posted May 11, 2020 @Ted could it be the valve body or shift solenoids? Quote
0 Ted Posted May 12, 2020 Posted May 12, 2020 22 hours ago, Devinda_Z said: @Ted could it be the valve body or shift solenoids? According to the Toyota Repair Manual for his Auto Box, if negative observations received upon above tests, they are the 90% possible causes. I am sorry that is only what I can say. Quote
Asanka Pubudu
7 answers to this question
