Odometer on vezel/grace
CARLOVER99
You can't really identify a tampered odo with 100% certainty but there are some things you can try:
1. Ask for service records. If the seller has service records from the authorized dealer you can verify those records with them
2. Check around the odometer for physical damages. Tampering with the odometer often requires disassembly of the odometer (yes, digital ones too) so there could be a mark or two left by a careless technician
3.  Check the physical condition of the car. Multifunction buttons or handrests cannot be faded in a car that has done only 50k
4. Verify auction papers online if its an unregistered car via https://jpcenter.ru/report, costs $10. Verify inspection reports (JAAI/Jevic reports) too while you're at it
5. Get the car inspected and scanned by Carchecks. The ECU records the mileage each time you clear DTCs so there is a slight chance of tamper detection through a scan
Edited by Hyaenidae
5. Get the car inspected and scanned.....The ECU records the mileage each time you clear DTCs so there is a slight chance of tamper detection through a scan
For 2>>I looked about online to educate myself on the matter as I was so out of it and what I discovered was that most of the methods utilized to roll back odometers simply involve a connection via the OBD port, so no disassembly required. One method (involved in stopping the odometer rather than changing it) did involve the disassembly of the dash, but I feel our fellows are working via the OBD port; so there may not be evidence of tampering- BUT certainly: It doesn't hurt to look...
For 3>> Do you know the scan tool (OBD2 scanner and version) that allows you to do this? Would be a super useful tool to have, not only to check for mileage but also to check for jury-rigged repairs when buying older cars...
Edited by Kavvz
The few people I know who are in this business go through the disassembly route though. I'm guessing Japanese cars need disassembling the odometer and changing values stored in the EEPROM. Have you seen someone changing the odometer value of a Japanese vehicle (especially JDM) using the OBD port?
Did you mean #5? I think it's the launch X431. (Maybe cheaper iterations of Launch scanners are capable of this too, X431 is the top-of-the-line version. All I know is it IS a launch scanner :D)
The value "65535" doesn't change after passing that mileage so this car could've been cleared of DTCs after running 100k kms, but it's useful to confirm mileage tampering nevertheless, as long as the new (false) mileage is below 65535kms
Edited by Hyaenidae
Awesome! Good one @Hyaenidae
Edited by Kavvz
Personally no. Via online tutorials and discussion forums/boards: Sadly yes.
Not sure if they were specifically JDM models but there was a number of Japanese makes supported by this OBD tool (Nissan, Mazda, Mitsubishi, Toyota were on the list of supported vehicles, but not Honda). Its sadly quite cheap and widely available on eBay and Amazon... ?
  • Sad 1
Thinking about the number '65535' in a different way. Its 2¹⁶-1. See here https://en.wikipedia.org/wiki/65,535
