I have 2006 Liana 1.6 L auto. Recently I made a total engine repair and replace the gearbox. The previous user had used only water as the coolant. However, after the repair, I serviced the radiator system and then put Havoline premixed coolant after a few days. But recently I discovered my overflow tank getting empty. The reason I thought was radiator cap as I roughly removed the corrosion under the radiator cap. So I replaced the radiator cap. However, without a rapid pace and quick intervals, I still feel like I'm losing coolant If I run the car more than 70Km. Short distant hasn't reduced my coolant level but long-distance dose. And there is no sign of leakage on radiator cap or horse. And also vehicle doesn't get heated up. indicator is in the middle between C & H. What shall I do? Is it a gasket fail?
Edited by Suzukui Liana 2006 1.6L au More information
Hi guys,
Edited by Suzukui Liana 2006 1.6L auI have 2006 Liana 1.6 L auto. Recently I made a total engine repair and replace the gearbox. The previous user had used only water as the coolant. However, after the repair, I serviced the radiator system and then put Havoline premixed coolant after a few days. But recently I discovered my overflow tank getting empty. The reason I thought was radiator cap as I roughly removed the corrosion under the radiator cap. So I replaced the radiator cap. However, without a rapid pace and quick intervals, I still feel like I'm losing coolant If I run the car more than 70Km. Short distant hasn't reduced my coolant level but long-distance dose. And there is no sign of leakage on radiator cap or horse. And also vehicle doesn't get heated up. indicator is in the middle between C & H. What shall I do? Is it a gasket fail?
More information
7 answers to this question
