Toyota C-HR - Problem in Fuel Injectors (GDI)
On 8/16/2020 at 10:14 AM, CNX said:
The following was copied from an email sent by Toyota technical/customer service to a customer in UK
1) Root cause of the misfire was due to a circuit inside the ignitor being contaminated in production. Counter measured with a change in production operation.
2) This issue will not reoccur, as modified coil packs have been fitted.
3) No investigation is outstanding on your car's misfire issue.
4) Ongoing investigation for carbon build up on low speed driving vehicles and short trips is ongoing but not relevant to your vehicle.'
Go to Spark auto kadwatha, They have a solution for CHR Injector issue. Before you visit there call and reserve a time slot otherwise you have to wait a whole day there...
  • Replies 77
  • Views 151.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Update: Next, he immersed the injector in a solvent bath for about two days (tip only) and then cleaned the injector 3 times by ultrasonic cleaning. and tested withย WD40 as well. No improvement i
  • Well our perception on Toyota's are based on the 90's and early 2000's models such as the Corollas, Vitz's and GGG's (God's Greatest Gift) with relatively uncomplicated internals where little could go
  • Well..the point was that Toyota is NOT NEW to direct injection engines. I might have misunderstood your initial statement about Toyota being new to DI engines (I suppose you meant for small high compr
Posted Images
On 8/1/2020 at 12:26 PM, Dee Jay said:
This seems to be a common issue with the CHR.. there were many members in the FB group that was affected by the same issue..
I read in some comments that Toy#ta L#nka charges around 70k to replace the injectors and it can be fixed outside around 55k. Don't know the validity of the comment as I have not personally observed this fixing.
Is the injectors out of stock at Toy#ta L#nka or they haven't brought it down yet at all?ย
  • 1 year later...
I also have this injector issue on cylinder no 2 of my chr, misfiring 53k but i used 95 oct all the time
