After using my car battery for quite long, i added distilled water yesterday. Today morning I saw the plastic case which the battery holds is wet. There's no lot of liquid, but under the battery was wet. Should I be worried ? Did I overfill the battery ?
Thanks for the recommendations. Should i go to mechanic or wait and see if it sort out ? I have long trip in coming days with family and don't want any problems in road.
what happened with your issue? did you get the charging checked. It's always good to leave a feedback as to what was the cause and remedy as someone will learn a thing
I did not go to mechanic. It was not any leak. It was overfill. After few days it was ok.
