I have a Kia Picanto 2005 (Manual), 135000km done.
This happened recently,
One tire get stuck when driving for a few KMs and noticed the pins and the tire cup is hot tempered (with a burning smell). Also feel the power is losing (not all the time) and sometimes misfiring. And noticed that the radiator water reservoir was boiling when stopped the car (not all the time). Only once showed the heat went up. When this happens I park the car and switch off the engine for 10-15 mins). Then everything back to normal until I run for another few KMs.
Changed the brake pads, CV Joint, cleaned the caliper including the piston and pins, replaced the caliper piston boots and caliper pin boots. Sometimes the tire is rotating smoothly but sometimes getting stuck. Recently replaced the brake booster (recondition one). Only once or twice noticed the brake pad is little hard to push.
The garage guy said need to replace the Caliper as there are some scratches inside the Piston hole.
And, noticed a small oil leak from the sump packing but I don't think that it is relevant to the above issue, planning to replace them next week. No oil in the radiator and head gasket is also good (no leaks)
Any idea? the radiator and the cooling system is blocked? Injector issue? or the caliper?
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Iroshw
4 answers to this question
