Can a honda gp1 ground clearance be increased if so will there be performance reduction and will it be dangerous to drive.
4 answers to this question
depends on what you plan on doing to increase the height..
You can increase the tyre size diameter and see.. however there will be a significant reduction in fuel consumption
4 hours ago, Mah said:
Considering in placing a spacer under the coil springs
that may have adverse affects in highspeed cornering. if ur a slow driver it would be ok i guess.
