This is a 1999 Mazda familia BJ5W 1.5L manual transmission. There is an engine miss at times, plus when picking up from low rev/speeds there is a delay of 3 to 4 seconds before any power comes. Even if the accelerator is pressed in full the car does not get any power until 3 to 4 seconds pass by. This does not always happen, but happens regularly, especially when picking up from idle/traffic stop. Also at times the RPM fluctuates at idle, again this is also not all the time. When going up a hill and a lot of power is given to the engine, a ticking sound can be heard from the engine. All of these happen intermittently.
Below are the repairs already done due to this issue, but has still not fixed the issue.
1. Replaced plugs
2. Replaced plug wires
3. Replaced both coil packs
4. Replaced Air filter
5. Replaced Fuel pump and fuel filter
6. Engine tune up was done including throttle body clean
7. Air flow sensor was cleaned also tried another 2 (used) air flow sensors, still no difference
Rahman Mohamed
1. Replaced plugs
Anything else that can be done?
Edited by Rahman Mohamed2 answers to this question
