I have a Honda Civic FD4 - 2008 with mileage 150,000km Stafford maintained. There is a jerk in the gearbox when I put onto the reverse every morning. Once it happens, it is there when I put to D also. If I switch off the car and on again, problem disappeared. It happens only when the car is started after long rest. ATF also changed very recently. Any one came across with the same problem and know a solution? Thank you.
  • 11 months later...
Did you fix the issue?
