Hello friends. I am new to the forum . I have Toyota axio 2007 X grade with manual AC control . But same car G grade has climate control AC . I just want to know can i convert manual AC to climate control
Edited by iRage
  • iRage changed the title to Toyoa Axio (2007) - A/C conversion (Manual to Auto)
Welcome to the forum. As you can see I made some changes to the thread topic :)
To answer your question...yes..you can convert it...you will need to change the electronics (including adding a few sensors) and the control panel. I beleive the easiest would be to get the entire system from a G grade car and fix it on to your's. No idea how much it would cost but probably a lot.
Thank you for quick reply.
