Bai Posted February 16, 2022 Share Posted February 16, 2022 (edited) Hi guys, I was looking for for answers to what has happened to my honda vezel and came across this thread. Am experiencing the same problems, went to the workshop and got the diagnostics done (see image). Said that they had to recalibrate my car, and changed the battery. It was all good until today - two days later. SAME thing happened. All the warning lights came on after I started the engine. Is it the battery again? When I drove up a slight slope, i could feel the car slightly rolled back before it picked up as I stepped on the pedal. Could this be a gear issue as well? I am the first owner, and had the hybrid vezel for about 5yrs now. The best part is that the car went thru it's regular servicing about 2 months ago. This is really stressful. Any thoughts on what could be the issue? Edited February 16, 2022 by Bai Included image Quote Link to comment Share on other sites More sharing options...
Bai Posted February 17, 2022 Author Share Posted February 17, 2022 Hi guys, I was looking for for answers to what has happened to my hybrid honda vezel and came across this website. Am experiencing a problem whereby warning lights came on as soon as i started the engine! Went to the car workshop and got the diagnostics done (see image). Said that they had to recalibrate my car, and changed the battery. It was all good until today - two days later. SAME thing happened. All the warning lights came on after I started the engine. Is it the battery again? When I drove up a slight slope, I could feel the car slightly rolled back before it picked up as I stepped on the pedal. Could this be a gear issue as well? I am the first owner, and had the hybrid vezel for about 5yrs now. The best part is that the car went thru it's regular servicing about 2 months ago. This is really stressful. Any thoughts on what could be the issue? Thanks! Quote Link to comment Share on other sites More sharing options...
tbird Posted February 17, 2022 Share Posted February 17, 2022 (edited) Most probably this issue is related to wheel speed sensors (ABS Sensor), it is connected to stability control, EPS, hil start assist etc. I had the same issue in my Ford Focus and had to replace front wheel speed sensors. Then it is resolved. In addition, this can come if the 12V battery is week, but you say you changed the battery so this could be one or more faulty wheel speed sensor Better to do a live scan and see speed sensors give live data, means you need to connect the scanner and drive the car and check all the wheels give speed data. If one or more sensor gives zero or constant high value (my front sensors gave 260 Km\h which is the max value according to the speedo meter), it is a faulty sensor Edited February 17, 2022 by tbird 3 Quote Link to comment Share on other sites More sharing options...
Chaudhary Ubaid Posted June 16, 2024 Share Posted June 16, 2024 Hi im facing a problem in honda vezel 2021 . When speed goes agove the 40km the side slip lamp is blink and car lose its power . Below the 40kmph the car is good . And the thing that confuses me is when we plug off the battery and again plug in All the lamps show on screen and car drive perfectly even more then 40km to 180km Quote Link to comment Share on other sites More sharing options...
iRage Posted June 17, 2024 Share Posted June 17, 2024 On 6/16/2024 at 7:19 PM, Chaudhary Ubaid said: Hi im facing a problem in honda vezel 2021 . When speed goes agove the 40km the side slip lamp is blink and car lose its power . Below the 40kmph the car is good . And the thing that confuses me is when we plug off the battery and again plug in All the lamps show on screen and car drive perfectly even more then 40km to 180km Expand Have you done an ECU read out? Sounds like your stability control system is having some sort of issue and is thinking that the car is about to slip and is cutting down the throttle. So it could be that the sensors have gone bad or the control unit itself has gotten spoilt. You should do a scan to check for any error codes. NOTE: when the stability and traction control systems are functioning properly it cuts down the power and slows the car down to stop it from slipping. Quote Link to comment Share on other sites More sharing options...
