Considering DPF/DPD filter deleting or removal for my Isuzu Elf 2015 Lorry. Is it safe to do so ?
If I delete/remove DPF/DPD filter from my Isuzu Elf Lorry, I can use normal auto diesel instead of super diesel right ? So it safe to do a removal of DPF/DPD filter? Any recommended places and advice regarding this ? Thanks in advance
Can be done, but no experience on how it will pass the emissions test afterwards. You will need to physically remove the DPF, then proceed to ECU software alterations to delete it,
a good tune might also save you emissions trouble as well.
As for the environment, its not going to be that good.
As for using Normal Diesel, your injectors might not be compatible with normal diesel, so before you run into it, do more research on that.
  • 2 months later...
I would consult with experienced specialists about the issue of replacing the DPF, because there are many nuances, as far as I know. And if you've never had any experience with DPF, then it's best to turn to experienced people. I can recommend you a few such people if you need them more. I do a DPF cleaning every few months at this service -- 30minutedpfclean.com, and met with several specialists who understand the work of diesel engines, know how to replace DPF, and so on. Well, they know everything about cars; if you need any help, just PM me.
Edited by Homospaniel
