I own a nissan leaf 2012 ZEO model car.I bought a cheap Bluetooth OBD 2 scanner online for nissan leaf. I connected it through the info car app first after trying connect it says app connected to obd 2 device but doesn't connect to the ECU.
I checked it with leaf spy lite and pro app versions but it doesn't connect also.
After I bought another obd 2 scanner online which says compatible with nissan leaf and leaf spy app.But I get same result from that too.
I needed check some fault codes . As the scanners doesn't work . I removed the negative 12 v battery terminal and leave for about 5 minutes and start again and it doesn't make any difference in fault codes errors come right after like they haven't cleared. I think there's something wrong with the ECU of my car.
I need to know why OBD 2 scanner doesn't connect and if there's any other way to clear the codes without a scanner?
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Kalinga Jayawardhana
1 answer to this question
