SKAF Posted September 2, 2023 Share Posted September 2, 2023 I need to know a place around Colombo to purchase genuine NGK spark plugs for Mira ES car. Below are the part numbers. NGK IR SILKR6D10G - this is the original came in car Found on internet below are also compatible, but not sure. Denso IRIDIUM POWER IXUH20I Denso IRIDIUM TOUGH VXUH20I NGK IridiumMax LKR6AIX-P BOSCH Double Iridium YR7MII33X Appreciate your advise. Thanks Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted September 2, 2023 Share Posted September 2, 2023 Hi your brand of motorcar has an agent last known in Rajagiriya.try them, \ The Iri's will have too be sourced through a specialist or the net, but be prepared to pay Good luck.! TT. 1 Quote Link to comment Share on other sites More sharing options...
SKAF Posted September 16, 2023 Author Share Posted September 16, 2023 Thanks TT. Apparently agent is in Abatale and have the Daihatsu original part. However after cruising through Panchikawatta I could find the same part around same price. Yeah IR are costly. But engine is smooth again. Quote Link to comment Share on other sites More sharing options...
tiv Posted September 18, 2023 Share Posted September 18, 2023 I might have 3 of these (NKG IR) from my copen, imported from Japan. barely used as I upgraded to High Temp ones like after few km, if you can't find them new let me know. Will not be free though😁 as they cost a pretty penny new. But the Copen is Turbo so there might be a difference. Quote Link to comment Share on other sites More sharing options...
HVN Posted May 25, 2024 Share Posted May 25, 2024 Hi SKAF I want to find same spark plugs, can I know the details of Agent. I would be a big help. Quote Link to comment Share on other sites More sharing options...
