I need to know a place around Colombo to purchase genuine NGK spark plugs for Mira ES car. Below are the part numbers.
NGK IR SILKR6D10G - this is the original came in car
Found on internet below are also compatible, but not sure.
Denso IRIDIUM POWER IXUH20I
Denso IRIDIUM TOUGH VXUH20I
NGK IridiumMax LKR6AIX-P
BOSCH Double Iridium YR7MII33X
Appreciate your advise. Thanks
Hi
your brand of motorcar has an agent last known in Rajagiriya.try them, \
The Iri's will have too be sourced through a specialist or the net, but be prepared to pay
Good  luck.!
TT.
Thanks TT. Apparently agent is in Abatale and have the Daihatsu original part.
However after cruising through Panchikawatta I could find the same part around same price.
Yeah IR are costly. But engine is smooth again.
I might have 3 of these (NKG IR) from my copen, imported from Japan. barely used as I upgraded to High Temp ones like after few km, if you can't find them new let me know.
Will not be free though😁 as they cost a pretty penny new.
But the Copen is Turbo so there might be a difference.
  • 8 months later...
