Nissan Ecu Data Scan Ver 1.5
Pasan_Robotics
1. ECU Part Number
Nissan Identification part number
2. Data Display
Resizable window
Analogue and digital gauges
Peak value display
Parameters depending on ECU:
RPM
Air Flow
Air Flow Right Hand
Water Temperature (C or F)
O2 Sensor
O2 Sensor Right Hand
Speed (KPH or MPH) with tyre size correction
Battery Voltage
Throttle Position Sensor
Fuel Temperature (C or F)
Intake Air Temperature (C or F)
Exhaust Gas Temperature
Injector Time
Ignition Timing
AAC Valve
Air Fuel Base
Air Fuel Base Right Hand
Air Fuel Base Self Learn
Air Fuel Base Self Learn Right Hand
Injector Time Right Hand
Duty Cycle
Duty Cycle RH
O2 Sensor B1
O2 Sensor B2
Registers:
Closed TPS
Air Conditioning Switch
Start Signal
Neutral
Air Conditioning Relay
Fuel Pump
Thermo Fan
VCT
Waste Gate Solenoid
Air/Fuel ration (lean/rich)
EGR Solenoid
3. Data Logging
Parameters and registers as per Data Display
4. Active Test
Engine Temperature
Timing
AAC Valve
IACV Valve
Air/Fuel Base
VCT
Fuel Pump
Cylinder Off
Base Idle Adjustment
clear Self Learn
5. Self Diagnostics
Read Fault Codes
Reset Fault Codes
6. Speed Trial
Measured times (kph or mph):
0-60
0-100
50-100
0-xx
xx-xx
And many more options
Supportable Vehicles
Nissan Data Scan software has been tested on following cars:
AUS 200SX S14 (SR20DET)
AUS 200SX S15 (SR20DET)
AUS Maxima A32 (VQ30DE)
AUS Pulsar N14 (GA16DE)
AUS Pulsar N14 (SR20DE)
AUS Pulsar N15 (GA16DE)
AUS NX/NXR Coupe (SR20DE)
JDM 180SX S13 (SR20DET)
JDM Silvia S14 (SR20DE)
JDM Silvia S15 (SR20DET)
JDM Pulsar GTi (SR18DE)
JDM Pulsar GTiR (SR20DET)
JDM Bluebird U14 (SR18DE)
JDM Bluebird U15 (SR20DET)
JDM Skyline R32 (RB20DET)
JDM Skyline R32 GTR (RB26DETT)
JDM Skyline R33 (RB25DET)
JDM Skyline R33 (RB20DE)
JDM Skyline R33 GTR (RB26DETT)
JDM Skyline R34 (RB25DET NEO)
JDM Avenir PWN10 (SR20DE)
JDM Infiniti Q45
CAN '92 Infiniti G20 (SR20DE)
US 300Z Z32 (VG30DETT)
US Sentra B13 SE-R(SR20DE)
US '94 Sentra B13 (GA16DE)
US NX2000 (SR20DE)
US NX1600(GA16DE)
US '93 Altima (KA24DE)
US '99 Altima GXE (L30, KA24DE)
UK Almera N15 GTI (SR20DE)
UK 200SX S14a (SR20DET)
UK Micra K11 (CG13DE/CG10DE
UK 1993 Primera P10 (SR20DE)
FRA 200SX S14 (SR20DET)
FRA '93 100NX 2.0 GTI (=NX coupe) (SR20DE)
GER Almera NX (GA16DE)
GER 200SX (SR20DET)
GER '91 300ZX Z32 (VG30DETT)
Primera HP10? SR20DE(T)
Cefiro A32 VQ20DE
FIN 99 Maxima A32 (VQ30DE)
Here r some screen shots
IPB Image
IPB Image
IPB Image
IPB Image
And how do you suggest you connect your laptop to your ECU?
And how much is the interface and program going to cost? It definetly won't be free.
Considering you have to buy all that I say it'll be cheaper going to the agents, or and expert who already has the stuff.
  Pasan_Robotics said:
1. ECU Part Number
IPB Image
IPB Image
IPB Image
IPB Image
I very much like the idea..... U got anything for Mazda 323 GLX YOM 2000 ?
Madmax has a point too..... how much is it going to cost.....?
Then again.... I may do something stupid and bust the ECU .....
You need a Consult II or OBD II Data Cable in order to use the software....
1. ECU Part Number
2. Data Display
Resizable window
Peak value display
RPM
Air Flow
Air Flow Right Hand
O2 Sensor
Battery Voltage
Injector Time
Ignition Timing
AAC Valve
Air Fuel Base
Duty Cycle
Duty Cycle RH
O2 Sensor B1
O2 Sensor B2
Registers:
Closed TPS
Start Signal
Neutral
Fuel Pump
Thermo Fan
VCT
Waste Gate Solenoid
EGR Solenoid
3. Data Logging
4. Active Test
Engine Temperature
Timing
AAC Valve
IACV Valve
Air/Fuel Base
VCT
Fuel Pump
Cylinder Off
clear Self Learn
5. Self Diagnostics
Read Fault Codes
Reset Fault Codes
6. Speed Trial
0-60
0-100
50-100
0-xx
xx-xx
JDM Infiniti Q45
US NX2000 (SR20DE)
US NX1600(GA16DE)
GER 200SX (SR20DET)
Cefiro A32 VQ20DE
IPB Image
IPB Image
IPB Image
IPB Image
Hey guys u can make the cable by ur self. U only need comport.
Ya this soft is not for free. But u can find crak for it easley.
Ok here is the schematics for cable ( make it ur self ) http://www.plmsdevelopments.com/images_if/...ult_if_rev4.pdf
Download Program
http://202.43.226.57/NissanDataScan1_52.zip
Crack
http://rapidshare.com/files/4350981/upload..._Anilrgowda.rar
Pass
  Quote
www.sharestation.com
Still i also didn't try this. Coz i have no time to make that data cable. But as soon as posible i'll make it and test my FB14 (sentra).
HACK THE WORLD :D:D:D:D
Edited by Pasan_Robotics
This is very cheap. actually 500/= bugs is enoughf for this. hi hi heeee.
If u go to the agents can u play arround with ur car. hi hi heee u cant.
I like to play with my car using this software and using my electronic knowledge.
But if something goes wrong with ECU unit I hope to go to the A MW. :D
You can buy the cable off Ebay if you want,
You have cables for both ODB I and ODB II though you get more softwares available on the net for ODB II
this is not a new thing by the way guys people in SL have been doing it for years, a friend of mine got it done on his car in 2003, I think somebody who regularly comes to the drags helped him with it cos he was not very good with a soldering iron,
I will find out if anybody wants, his was a Nissan Pulsar
The com port bit could be bought from Unity Plaza or pettah or an old external modem cable with a com port could be used he he
I personally quite like the idea, but a bit of soldering involved he he
Soonly i hope to make that cable. after i do it, i'll put my results here.
Its new to me.
Its new to me.
Er actually guys there are freeware versions for OBD-2 that run on linux available. However getting your hands on the DB 16 connector required to plug into the Jap OBD socket is difficult. When I had my HXXda earlier tried hunting for the connector in Singapore but couldn't find it. The other option would be to use pin probes to plug into the obd socket but this is not advisable in case the contacts touch and short something out.
The other option would be to buy a pre-made cable but once again bear in mind that the jap cars use a particular type of socket, the euro's use a totally different socket, even of the basic obd2 protocol is the same. There are also some nifty software + cable packages that plug into your pocket pc's (HP Ipaqs...etc) for about Rs. 25 k which also function on the move. Not difficult to find them on the net.
Cheers,
MadMMx.
Cheers,
MadMMx.
Hi hi heee pin probes r grate for me. Or im going to hack my connecter.
This soft is grate for my future home made Intel P4 CAR pc.
Hi Pasan and others,
Do you know where I can buy these OBD2-serial (or obd2 USB) cables in sri lanka ?
I recently got a Suzuki Swift SE-Z (2003 model), and really interested in connecting to it's OBD port via my laptop.
best regards
Thiwanka Wimalasuriya.
Senior Software Engineer,
EFutures (pvt) Ltd,
No 46 ½, Castle Street,
Colombo 8
Sri Lanka
Voice +94 112375140
Mobile +94 777481904
1. ECU Part Number
  • 4 weeks later...
There is a similar software to Nissan Datascan, its called ecutalk. It initially was just a home project this guy in sydney was doing, ended up to be a success. check it out at http://www.ecutalk.com/
In regards to the interface cable, u can either get hold of a serial or usb cable, obviously usb is expensive when compared to the serial. Here in Melbourne it will cost around the $125 mark (about LKR 12000).
I have the usb cable along with Datascan. I have to say the software is amazing. Saves you alot of cash. If any of u guys need to purchase the cable, shoot me a pm.
  • 4 months later...
well this is really interesting.. can anyone tell me from where can i get that data cable to connect my laptop with my car? (its a FB14) and how much will that cable cost?
thanks
