Sonuka Perera Posted March 21, 2024 Share Posted March 21, 2024 Hi, Reaching out to autolanka moderators since I have had no luck in order to figure out how to sort this. im looking to buy a Subaru XV and I checked many through Car checks. but I have a hard time In order to figure out how much it will cost to fix the issue mentioned in the car check report. Even senok is incomplete when they check on the issues and they don’t apparently check hybrid battery conditions. any advise on how to proceed is appreciated. Quote Link to comment Share on other sites More sharing options...
iRage Posted March 22, 2024 Share Posted March 22, 2024 Well...if you have the list of things that need to be repaired from the CC report, can't you go and get a quote from the agents for the repairs ? If the issue is with the Hybrid system and the agents do not repair Subaru Hybrid systems then I would say go to a reputed Hybrid specialist and get a quote from them. Since Subaru Hybrids are not that common I doubt anyone will be able to give you a quote at the drop of a hat like for an Aqua or Prius or something. Quote Link to comment Share on other sites More sharing options...
Sonuka Perera Posted March 22, 2024 Author Share Posted March 22, 2024 Thank you for the reply @iRage On 3/22/2024 at 2:49 AM, iRage said: Well...if you have the list of things that need to be repaired from the CC report, can't you go and get a quote from the agents for the repairs ? Expand This is the first thing I tried and then senok mentioned they don’t issue estimates for third party checks. so I placed that said vehicle for senok inspection and they didn’t properly detect any issue which car checks detected and when I questioned all their excuse was they don’t usually check on this. it was a disappointment. On 3/22/2024 at 2:49 AM, iRage said: If the issue is with the Hybrid system and the agents do not repair Subaru Hybrid systems then I would say go to a reputed Hybrid specialist and get a quote from them. Since Subaru Hybrids are not that common I doubt anyone will be able to give you a quote at the drop of a hat like for an Aqua or Prius or something. Expand I will have a look at the same. That will resolve 1 of the issue. Quote Link to comment Share on other sites More sharing options...
Gambino Posted April 3, 2024 Share Posted April 3, 2024 Hi has the issue being sorted. If not can I know whether issues you have are hybrid battery related or other mechanical issues? If its mechanical, I suppose you know that there is a reputed guy in Kottawa who does Subarus. I also once took my XV to him. Try that. Quote Link to comment Share on other sites More sharing options...
Sonuka Perera Posted April 3, 2024 Author Share Posted April 3, 2024 On 4/3/2024 at 7:17 AM, Gambino said: If its mechanical, I suppose you know that there is a reputed guy in Kottawa who does Subarus. I also once took my XV to him. Try that. Expand Hey Thanks for your message. It's mainly mechanical. Although i'm still looking for a hybrid specialist also. My main concern is that Car checks have mentioned there's a jerk in the gearbox. Senok couldn't figure out the issue. I've test driven it and i also feel there's a vibration when changing gears. Unfortunately i have not hear about the guy in Kottawa. Will you be able to state the person. It would be a real help. Quote Link to comment Share on other sites More sharing options...
Gambino Posted April 3, 2024 Share Posted April 3, 2024 Sure I will DM you his contact number. Quote Link to comment Share on other sites More sharing options...
