Supun AJ Posted September 14, 2024 Share Posted September 14, 2024 guys today i was stopped by a cop and he told me beat mufflers are prohibited in sri lanka.i was driving this car for now 6 years this was there when i brought it from Japan. Does anyome know the legal aapects of this? Quote Link to comment Share on other sites More sharing options...
iRage Posted September 16, 2024 Share Posted September 16, 2024 On 9/14/2024 at 12:39 PM, Supun AJ said: guys today i was stopped by a cop and he told me beat mufflers are prohibited in sri lanka.i was driving this car for now 6 years this was there when i brought it from Japan. Does anyome know the legal aapects of this? Expand You are not allowed to modify the car (i.e. change it from original/factory spec) without the approval of the RMV and subsequent endorsement by the RMV certifying the modification in the CR. So, the only way a "beat silencer" is acceptable in SL is if and only if you can prove that the exhaust came with the car from the factory (e.g., performance exhausts in cars like WRXs, Evos, and other performance-type cars). Now...if the exhaust was fitted in Japan it should be JASMA certified. Sadly that is not recognized in SL unless the manufacturer fitted it. If this actually was fitted in Japan, then it should not be loud, especially at low RPMs, which is probably why it didn't cause you any trouble with the authorities all this time. This time around, there probably was something else that drew their attention to you. Either, for some reason, the exhaust was loud (slight leak ? you revving too high?), or the cop just looked at the car and noticed the large tailpipe diameter. Sadly, there is no proper legal aspect for this. There is nothing that tells what the tailpipe sound levels should be (what there is for the front horn). Then there is also the fact that cops don't have proper sound measuring equipment so it is just the cop's word against your's. These cops have no idea about cars and which is what. So you are at a disadvantage right from the get-go. Even if you can disprove the cop, then they still can hold you for illegally modifying the car from its original specification (even if it is done in Japan). This has been an age-old battle, and no one has found a way around this. Go to the police station after putting on a standard exhaust or with evidence to prove that it is a factory-installed item. Quote Link to comment Share on other sites More sharing options...
Supun AJ Posted September 28, 2024 Author Share Posted September 28, 2024 It was there when it came from Japan. I don't want to modify it. Also i don't have evidence to prove it. It is always my words against them. Thank you for the info Quote Link to comment Share on other sites More sharing options...
iRage Posted September 30, 2024 Share Posted September 30, 2024 (edited) On 9/28/2024 at 4:09 PM, Supun AJ said: It was there when it came from Japan. I don't want to modify it. Also i don't have evidence to prove it. It is always my words against them. Thank you for the info Expand sadly your word is going to carry less weight than that of an ignorant cop. If it was fitted in Japan then it is JASMA certified but if it was an aftermarket install and you can't find an official catalog that would have had something similar as an option, you are sadly out of luck. The pain that limits everythingis someone went and put the term "mul arkruthiya" in the actual legal clause. By the very definition of the term no one can do anything to the car other than the manufacturer and the manufacturer has done. Edited September 30, 2024 by iRage Quote Link to comment Share on other sites More sharing options...
