Are you experiencing yellowish dull colored Headlamps? Here’s the Solution which is Simple, Easy and “Cheap”. What you just need is,
• 1 Bottle of Brasso (Small Bottle would be enough).
• Cleaning clothes. (For wiping purposes).
Get one of those cleaning Clothes. And pour Brasso into it. Just wipe through the headlamp up to 20-30 mins. Don’t let brasso to dry on headlamp lens cover. When cloth is getting dry add more brasso to the cleaning cloth and wipe again, Hard as you can. After 20-30 mins of wiping, just let it to dry and move to the next lamp. Let both lamps to dry and after 5 mins of drying just wipe all the brasso left on Lens cover using a new cleaning cloth. Experience the difference. I have done this to my Corollas (121) Headlamps and now they look like new lamps. Worth a try guys. :rolleyes:
Edited by Ruslan
Even cheaper Tooth Paste-which is also finer so a better finish-apply with slightly damp cloth-buff in a circular motion and wipe off with damp cloth.
Maithri
Maithri
I've tested the toothpaste method too.. but it's not effective as Brasso (Which is a proven compound). :sport-smiley-004:
Edited by Ruslan
There is a 3M plastic cleaner. It is also very good for this job.
Thanks Ruslan for giving us the cheapest way of doing it!
Thanks Nilantha for suggesting the most expensive way! :rolleyes:
Thx this is really interesting, i will also give a try? This to do on headlights outside surface right? I though yellowish color happens from inside lamp. Also how much will that 3M solution cost?
Edited by lasa
around 1000/=
Toothpaste is a much finer compound and thus required more effort !! but its much safer on plastic
