roadhog Posted July 4, 2008 Posted July 4, 2008 The car 1999 Impreza 1.5 JDM with auto transmission There is a engine mis/ vibration after engaging D in the morning and goes away after a kilometer or so. again between 2000 4000 RPM this comes on again. Any ideas. Quote
0 Arc Angel Posted July 4, 2008 Posted July 4, 2008 The car 1999 Impreza 1.5 JDM with auto transmission There is a engine mis/ vibration after engaging D in the morning and goes away after a kilometer or so. again between 2000 4000 RPM this comes on again. Any ideas. Is there anyway you could clarify if it is a miss OR just vibrations? Cos the two would have seperate causes.. If it is a miss then it could be plug or distributor cap related... Vibrations could be caused by faulty mounts... (just a few of the possible reasons) Lets wait for fellow Sub drivers to give their comments. Quote
0 roadhog Posted July 4, 2008 Author Posted July 4, 2008 This is an engine mis that causes the vibration. The mis is abvious after engaging D (under load) and goes away when the engine has heated up. even when the engine is hot if i try to overtake suddenly going more than 2500 RPM then there is a vibration (which I belive the mis is causing). Quote
0 roadhog Posted July 4, 2008 Author Posted July 4, 2008 Any thoughts from the subaru owner before I go to the agents !! Quote
0 Elvis_Pil Posted July 4, 2008 Posted July 4, 2008 Fuel pump or fuel related issue. Check your injectors. Sub's are sensitive to fuel as they need premium unleaded which we dont have. Quote
0 roadhog Posted July 4, 2008 Author Posted July 4, 2008 Fuel pump or fuel related issue. Check your injectors. Sub's are sensitive to fuel as they need premium unleaded which we dont have. Quote
0 roadhog Posted July 4, 2008 Author Posted July 4, 2008 I did add a can on injector clearner WRUTH no change. Quote
0 Elvis_Pil Posted July 5, 2008 Posted July 5, 2008 wont help if there is something already bust in th fuel system Quote
0 srajendr Posted July 5, 2008 Posted July 5, 2008 wont help if there is something already bust in th fuel system Don't have a Subi but had a similar problem when I bought my Honda. Spark plug wires were bad - worth checking them out before changing anything. Good luck! Quote
0 priya Posted July 5, 2008 Posted July 5, 2008 Fuel pump or fuel related issue. Check your injectors. Sub's are sensitive to fuel as they need premium unleaded which we dont have. I dont think so! Premium gasoline is factory recommended only for WRX and STI not for 1.5 models according to specs, like the one he is having..normal regular gasoline would do. Quote
0 priya Posted July 5, 2008 Posted July 5, 2008 Don't have a Subi but had a similar problem when I bought my Honda. Spark plug wires were bad - worth checking them out before changing anything. Good luck! Suggest checking Plugs/Wires(leads) first and then going toward fuel. Quote
0 GihanFX Posted July 5, 2008 Posted July 5, 2008 The car 1999 Impreza 1.5 JDM with auto transmission There is a engine mis/ vibration after engaging D in the morning and goes away after a kilometer or so. again between 2000 4000 RPM this comes on again. Any ideas. Check the Coil Pack, Plugs or the fuel Pump, btw if u intrested in a MT Gear box i have one Quote
0 dpbatagoda Posted July 7, 2008 Posted July 7, 2008 Check the Coil Pack, Plugs or the fuel Pump, btw if u intrested in a MT Gear box i have one Hi, I had the same problem with my vehicle and I took my vehicle to Pala Auto. They figured out that it's coming from loosy Air Cleaner. Then it's removed at refitted.Then it reduced a bit but didn't fade away all. Then they figured out some metal part in remote sensor box is touching with vibrating parts in vehicle and the vibration coming from it. Then it was removed and refitted and vibration fade away fully. Darshana Quote
0 roadhog Posted July 7, 2008 Author Posted July 7, 2008 Thanks guys, I took it to senok, they first checked the coil(which is at the top with a new one) Then they went down do the plug wires and they were broken (the metal ends that connect the plug) So the problem was solved but the leads were 4000 each !!!!!. And on the fuel the 1.5 is going fine with what we have in this county and it does 9+ KMPL no ignition noise eaither Quote
0 priya Posted July 7, 2008 Posted July 7, 2008 Thanks guys, I took it to senok, they first checked the coil(which is at the top with a new one) Then they went down do the plug wires and they were broken (the metal ends that connect the plug) So the problem was solved but the leads were 4000 each !!!!!. And on the fuel the 1.5 is going fine with what we have in this county and it does 9+ KMPL no ignition noise eaither So the leads! This is the usual case with Agents. Over expensive! Quote
0 GihanFX Posted July 7, 2008 Posted July 7, 2008 (edited) So the leads! This is the usual case with Agents. Over expensive! Actually subaru parts are very Expensive and im planing to advert all the subaru stuff i have in AL , then can earn something Edited July 7, 2008 by GihanFX Quote
0 Ripper Posted July 8, 2008 Posted July 8, 2008 Actually subaru parts are very Expensive and im planing to advert all the subaru stuff i have in AL , then can earn something sourcing online is the cheapest IMHO I think folks like Sharkster are doing that already if i'm not wrong Quote
0 roadhog Posted July 8, 2008 Author Posted July 8, 2008 Gihan X - have you got brakepads for the 1999 model ?? Quote
0 Pericles Posted July 8, 2008 Posted July 8, 2008 No advertising on the forums unless its on the classifieds. Quote
0 GihanFX Posted July 8, 2008 Posted July 8, 2008 No advertising on the forums unless its on the classifieds. Yeap Yeap i come and put the Advet today Quote
roadhog
Any ideas.
19 answers to this question
